VrayDistanceTex and road markings
I have seen every tutorial on Youtube on this matter, Corona and Vray. WHY make this so god damn hard? Why haven’t Chaos made a road marking function plugin, instead of us having to go through these INTENSE way to make something as simple as white paint on asphalt? And I *never* get the same results as the tutorials, never ever. With basic default settings. It is so frustrating, even when I download the scene from the tutorial - it does not become the same as in the video. Something is always different, and I have to spend a lot of time to just get a barely satisfying result. And nothing like the tutorial. I am going over to AI rendered scenes, making huge prompts. No finesse at all unfortunately, but it gets the job done in minutes. I just tell the AI render engine what I want and just do post editing in Photoshop. This is a Kodak moment for Vray and every other 3D software. Make it much more easier to get the results that is wanted, or fade away.
/end rant.
Use a VRayDecal; it’s easier. Here’s a sample scene.
For more complex parts (arrows, icons, etc.), use a texture for the decal’s mask. ChaosCosmos has presets for these.
EDIT: Curves, however, will not work with this method.
The power of V-Ray or of a lot of renderers as a matter of fact, is that it provides you the tools to create about anything. Settings this up takes less than a minute. You can save this shader setup for future use case as a .mat if you don’t want to redo the whole process again. I don’t think it’s Chaos’ job to provide tools for each niche use case, there are plenty of tools available that you can mold to your liking and save for future reuse.
That being said, with VrayDistanceTex the setup is very easy, the basic shader takes 45 seconds to set up. If you want it done in less than there’s a lot of scripts out there that automate the process using the built-in tools that V-Ray provides: this one for instance: https://archviztools.com/road-markings-generator/
Without scripts:
