I am trying to create a texture mask that outlines the corners on assigned objects.
I am getting a weird triangular cut out when I use Vray Edges Texture. (Red and White just to highlight the problem)
Thanks!!
It’s a known issue (internal bug-tracker id: VMAX-5158 ). Not sure if there’s a workaround, except using lower size values or maybe VRayToon instead,
Thank you for your reply!
Grant xr3d,
Until chaos fix this issue, there is a free material plugin from Itoo which you can use. I think Color Edge is the name
Z
