VrayEdgeTexture on Bump Slot doesn't render fillet edges
I created a simple box and applied a material with grey diffuse color and VrayEdges texture on the bump slot but it doesn’t render the edges curved in fillet. I tried the map amount 100% and some other number but I couldn’t make it work.
Geometry is a primitive box with 6 poly.
I am using Vray 1.50 SP4a.
Solved the problem :slight_smile:
But couldn’t find a way to delete the post.
