VRayFastSSS
Hi!
3ds max 2008
vray 1.5 rc3
Are there any guides for settings for the fastsss material. I am doing a full body character with displacement maps applied. Those maps are at 2048 and it works fine with the vray displacement modifier. I had a dermal and subdermal layer map at 2048 tiff each which stopped the render engine cold. I have since reduced these to 1024 80% quality jpg which helps a bit.
I understand to get a good result GI must be used. Even a test render at a small size and GI noise threshold at 0.05 (which is unusable) its taking a while. Its not uncommon to have at least four maps on a figure: dermal, subdermal, bump and at least specular, so with only 2 applied I have 2 to go!
I think my GI settings are sucking badly along with a good strategy to set up the material. Any help appreciated.
Cheerio Chris
if your using rc3 then you need to request full forum membership so that you can ask your question in the normal forum along with all the other registered users
