VrayFur 1.5 explanation?
can anyone explain how the new vrayfur RGB mapping work? Nothing yet on the help section.
I understand how the ‘mono’ work, but no idea for the ‘rgb’
just make a small test with gradient ramp… the first image i put a simple gradient ramp map into “bend directional map” slot. The second image, in “initial direction map” slot.
I assume the RGB matches the Max internal directions as such:
Red is X
Green is Y
Blue is Z
Mixing values will push things in different directions… the refferential direction is probably the normal (Z being perpendicular to the face). I bet maps for VRay Fur behave very very similar to normal maps.
Isn’t it X=Red and Y=Green?
That’s the colour coding I have in my version of max.
You’re right, my mistake.
