VrayFur problems
Hello, i’m working in a animation with vrayfur. It seems the best fur for vray.
I’m having some problems with it, the most important is the density seems to be different when i put some modifier ti source object. The O letter is the same mesh in both cases.
I have vrayfur distribution per aren in both cases.
I need the same density in both letters. Is there any solution for this?
Well, the problem seems to be only when you have flex modifier and scale the object fron 0 to 100%
You can use the “Reference frame” parameter to specify the frame in the animation that will be used to calculate the fur density.
Yes, i thought like you but the reference frame parameter seems not work here. I have 1.5 SP2.
Can you send me that simple scene to vlado@chaosgroup.com to check it out? Does it work if you use the PointCache modifier to bake the animation?
