i have some problems with the usage of vrayfur. I need to create some sort of polyester fleece, so i`d tried to make a fur object with very low settings for length and thickness.
When i get under 1-2 cm for the length, vray isn`t rendering anything at all. With values over 2 cm it is rendering.
Is there a necessary minimum length necessary for vray to render fur or some sort of threshold or other parameters which can get rid of this behaviour ?
Thanks for help
Robin
