VRayHairNextMtl - changing materials via timeline
Hi, is it possible to change materials via timeline in the VrayHairNextMtl material? I make fabric renders created with VrayFur. I need to automate switching via timeline so that the color of the material in VrayHairNextMtl changes on each frame. On regular materials, I have various materials connected to Multi/Sub-Object and on a given model I “record” a change to a different fabric using the Material modifier, unfortunately it doesn’t work on VrayHairNextMtl, or I’m doing something wrong.
https://drive.google.com/file/d/1\_1L7YYHu74eeR6KbTYNeZLyLWZeV87Kj/view?usp=drive\_link
In the video I show what switching materials is all about.
I would be grateful for any tips :slight_smile:
Inside the VRayFur, there’s a “MapID” option, which works similarly to the Material modifier you are using in the video. Use it instead.
Thanks for the help, but unfortunately this method doesn’t work. I know why now, because I render on GPU and therefore it doesn’t change materials using MapID.
It works with VRaySwitchMtl but only on regular VRayMtl, unfortunately not on VrayHairNextMtl.​
Below is a recording of what it looks like:
Is there any other solution for this?
Try using the 3ds Max native “Material Switcher” material - it should work as expected. Otherwise, I’ll log both other issues for investigation.
EDIT: Logged as internal tracker id: VGPU-6758 and VGPU-6759.
It would be great if improvements could be made :slight_smile: The option with the native Material Switcher works, but there is no option to record in the timeline.
Huh, you’re right. It seems 3ds Max doesn’t allow the ID parameter to be keyed. The only workaround I see is rendering the animation manually through a script, where on frame change, the Material Switcher ID also changes. Here is a sample script:
fn MaterialSwitchKey =
startFrame = 0
endFrame = 3
for i = startFrame to endFrame do
rendTimeType = 1
slidertime = i
for each in sceneMaterials where classof each == Material_Switcher do (
if startFrame == 0 then each.selection = (i + 1) else each.selection = i
max quick render
try(MaterialSwitchKey())catch()​
It syncs the Frame Number with the ID of all Material Switcher shaders in the scene. I can adapt it to work for selections if you prefer. Simply edit the startFrame and endFrame value and run.
