I’m not used to working with Hair materials but right now I’m trying to create some fur.
So I was looking at the presets in the hopes to learn something from it, but when I select a preset (although the preview changes), none of the parameters change so I’m not sure what the values are exactly. Is that on purpose or a bug?
Also I was looking at an older model that still uses the previous Hair shader VrayHairMtl. But this one can’t be found anymore in the list of available materials. So probably still supported but only in the background?
Hi parameters change when I change a pre-set of the VrayHairNextMtl as well as preview and render.
I made the test in 3ds max 2023 and V-Ray 6, hotfix 3. What versions of V-Ray and 3ds max are you using?
Omg I’m so sorry the changes were so minimal between the settings (none of the colors changed), that I didn’t see some of the parameters did change. Well I told you I wasn’t used to working with hair :-|. Looking back at it afterwards it’s weird that to change the color we’re changing a spinner values instead of a color value. And because the preset dropdown is covering most of the values that change when switching I didn’t see it change when switching to another one.
