Hey,
I have a request here that would finally make the ancient color correct plugin obsolete. The only reason I still use it is that it has a clamp function.
This is quite usefull sometimes when you are lighting scenes with HDRIs, for example on night shots. Often the bright light sources create lots of fireflies in the reflection pass, which the Max Ray intensity can’t get rid of. So I use the color correct node and clamp the HDRI values at 10 or 20, and the problem is gone. Is it possible to integrate such a feature into the regular VrayHDRI?
Regards
Oliver
