VrayHDRI Loader - ability to drag/drop map into it.
With a lot of people using the Vray HDRI loader for loading standard 8bit maps instead of the bitmap loader, would be great if it would be possible to drag and drop a map into the VrayHDRI loader!
For playing with shaders this is essential. Having to navigate through windows explorer every time you want to load a map with vray HDRI is ridiculous.
If you mean the ability to create automatically V-Ray HDRI node when dropping a texture file in the Material editor, this is in our to-do list. Currently you can use the drag’n’drop for the V-Ray HDRI Bitmap field to load a file.
