VRAYHDRI Map visible in viewport?
i´m a vray newbie and have a problem.
I use 3ds 9 an vray 1.5
I use a vrayhdri map for environment and as map for vray domelight.
Is there any possibility to make the environmental map visible in the vieports?
I try to use it as environment map for max too, but the hdr is only in the rendering.
But i need it visible to arange my model proper to the hdr.
I hope you understand my problem.
And yes i used the search function :wink:
Greets
Map it into a sphere with a vray light material and turn it on in the viewports instead - you can use the light material multiplier the same way as your environment or domelight multiplier.
Thanks for your answer, this solution works.
Now I have to test ift the lighting wit the Light material is still the same as the domelight wit h the HDR Map.
The dome light has a few tricks built in to it to make it cleaner and quicker than using the sphere method but as you say it’s less easy to align.
