yes thats not a typo.
is there a way to revert a scene that has been converted to vray hdri loaders back to bitmap?
Nope. That’s why the docs specifically mention to save the scene before converting ![]()
Would there be a way to have the converter transfer dialogue adjustments per bitmap loader? It seems to just transfer the texture map but not any tweaks applied to the loader settings. I’d use it more often if it had this function.
Which adjustments do you have in mind?
Typically, what my animators are adjusting is Coordinates and Output. Not sure if the Curve can be transferred but they tweak color with it. The current convert stripes those adjustments and changes the end result.
Are you aware of a script that would allow global adjustments to be made to the VRayHDRI loader? The script I’ve been using seems to crash my scenes now. I’m just looking for a way to quickly switch Color space and Filtering on all loaders.
Thanks for your time!
you can change parameters of filtering or any accessible vrayhdri parameter with vmc script. I think (not sure) Neil soulscripts also have similar feature. both are great scripts.
of course they do not transfer curves or coordinates. just bulk edit of parameters.
the curve can be transfer even if not in vrayhdri you can just instance the vrayhdri in an outputmap and transfer the curve. you do it in your studio it will be pretty easy to produce such script. but about the coordinates I have no idea because I do not use them.
Thanks! VMC is the one I’m currently having issues with…I’ll try Neil’s.
