vraylight directionality, square artifacts
When I use directionality on a plane light and reach 0.65, there are square artifacts near the openings. Take a look at the attached file. (bucket rendering)
Can you send us a scene file that reproduces this behavior to support@chaosgroup.com ?
email sent! thanks!
Thank you. I just sent you an email with the results of my tests here.
Does it go away if you switch the lights evaluation method to “Light tree”?
yes, but it was slower and renders slightly different.
did you find out what is the problem?
We don’t have a solution for this issue yet. Will let you know when we have any progress..
