Vraylight edititing grayed out
I discovered recently a problem with my Vray: the “edit light” option is grayed out and I can’t do any changes. I have SU8 Pro and Vray 1.49, windows7 64 bit.
I might be an interference from some plugin that I installed recently but I have no idea which one could do this.The various plugins are from the Sketchucation forum and they work well enough.
I suspected that the VrayLumen could be the culprit but it turned out I was wrong.
The only way I can work around the problem is through the VrayLumen panel, but apparently it doesn’t work with IES light.
May be there is a keyboard shortcut to bring up the light editor?
(I also made the same posting in the “Public” section but I think this is the right place)
Re: Vraylight edititing grayed out
Either you have old versions of Fredo’s plugin, which caused menus to grey out.
Or you have so many plugins installed that SketchUp has trouble managing the menus.
First ensure all your Fredo plugins are updated, if they are, then get rid of plugins you don’t really use.
Thank you, Thomthom, I knew somebody here will know!
I’ll check the Fredo plugins first and I’ll let you know what happens.
Later today: Thomthom, you were so right! I installed the most recent Fredo plugins and voila! everything’s fine.
Thank you, I knew someone here would help me.
;D
And a cool feature of the latest LibFredo is that it has a Check for Updates function.
