Hello, Chaos, here is an issue that is an obstacle:
I think everything is set properly, but the map doesn’t seem to be functioning at least no pattern is visible:
Can you help with it, please?
I’ve tried changing the scale and no effect. However it works with another map. What could it be?
Hmm, not sure why. It seems related to the mapping since using an explicit map channel works as expected (check the attached scene). I’ll troubleshoot some more and report back. Another workaround may be to simply bake the Noise and plug the VRayBitmap instead.
noise_vraylight.7z (34.5 KB)
Thank you, I think I’ll have to update to see it working. However I am also upgrading the machine I have and will be few days before that happens, so thank you again and see you soon!
