A ground plane and several vray lights. All the vray lights are set to “include” various objects.
The groundplane is lit by a simple white from the vray Environment Dialogue. No Vraylight Affects the groundplane.
In the rendering, the light sources seem to to cast shadows from the environment on the ground plane.
A pretty undesired effect. Anything that can be done about this in the short term, without ripping the scene
apart in various layers ?
I was really intrigued by this one and just had a quick try. the lights don’t seem to actually cast shadows on the ground, they rather make darker what they should cast light on, if the object is excluded. if you make them double sided you’ll see the “shadows” going both directions.
using a dome light instead of the environment seems to help a bit, but the problem is still there, even if fainter. weird.
edit: well, it seems related to gi, if you turn it off the problem disappears.
Hm, ok. Another option would be to put a VRayColor texture on the lights, and set its alpha to 0.0 so that they are completely transparent, but still emit light.
Yes, this works more or less. The shadow is gone , but with alpha 0 it get´s brighter than the actual groundplane, wich is not pure white in my case.
(I added this texture just to the light on the left)
I can adjust the alpha and get a nearly clean result at around 0.3.
But it ´s still not perfect. It somehow looks a bit dirty in this area.
Anyway, for the preview today it will be ok.
Interesting, I have always wondered about the unwanted shadow when excluding lights from floor geometry - I have had this problem when using VRay lights positioned close to the floor in a studio car render setup.
So is this being solved for RT in the next update in December 2011? Seems to only be an issue for me when using OpenCL. CPU doesn’t cause these mysterious shadows. AKA Ghost shadows.
Hey sorry for the lag but here it is…
Is it just impossible to get rid of this vray light plane (dark) bug using openCL for the time being-as of January 27th, 2011?
I’ve noticed that a vray light (even set to invisible) will also block reflections coming in from other vray lights such as a dome light with an HDRI. Not the end of the world but I do wish that it didn’t do that…
Has this been fixed? I’m still getting a shadow from the light object in the gi pass.
The light is set to invisible, and that parking lot plane is excluded from the light. I even tried the trick of using a Vraycolor map in the light with the alpha set to 0.0 but I’m still seeing the shadow of the light object
I just tried this with every permutation of setttings/gpu/cpu but can’t get that result (Vray 5), so maybe it is something else.
Does it still occur with only the light and the specific plane visible?
If it does, you could post just the light and plane and we’ll see if it happens on others’ machines
I’m just speculating without the scene, but it will happen in V-Ray 5 if you turn on “Occlude other lights”. Making it just invisible shouldn’t produce shadows.
