hello. for me, vray update 6 v2, vray light meter says “no v-ray render engine found” when i hit calculate on a vraylightmeter helper object.
the vray render element does seem to work. although i’m not getting accurate results. in the scene i claim are not accurate results, the lights are set up with IES files in a vrayIES light object. they are at the required hights and locations and also orientation.
using 2 RTX GPUs note also that a defualt simple scene 1 box 1 sphere 1 plane with vraysun/sky gives the same error when trying to calculate the lighter meter.
also, for the scene, i’m using a material override and the grey value seems to affect the results of the lightmeter overlay in the render element. is there a common grey value that is used?
