VrayLightMtl cant show correctly
hi, got a problem, how to show VRayLightMtl_02 like VRayLightMtl_01?
below is scene file
VrayLightMtl.zip (110 KB)
is it i miss set something? render result is same, just viewport show differently.
Turn on the realistic material preview for that material in the viewports and it should be fine.
how come VRayLightMtl_01 no need to turn no realistic material can show mapping too?
I don’t know; may be the map itself has the option to show the map in the viewport enabled… I haven’t looked at the scene yet, sorry.
What I tend to do is put the VrayLightMtl in a shell material and instance the bitmap to a new material that is viewport enabled.
not sure why my standard material editor cant enable show map in viewport correctly, after change to slate material editor no more problem already, thanks.
