VrayLightMTL causing noise
Hi
I am trying to make cove lighting, the way I did it was I applied a Light MTL to a renderable spline set the amount to 10, But as you can see in images below that it gives me this unwanted noise I cannot figure out why this is happening?
Please give me some advice; I am new to vray, and have a deadline approaching
I am using vray 1.5 with viz2006
My settings are
IR map set to high- LC Subdivs 1000- Fixed image sampler subdivs 4
With the cove lighting object
Without the cove lighting object
You should increase the hemispheric subdivs for the irradiance map, or alternatively, use VRayLight’s instead of the VRayLightMtl.
I tried that already, I was at 30 and pushed it to 40, should i try 50, wouldn’t that give me huge render times?
I guess I will rather use vray lights,
im supprised how low some people keep it. i never (as i said in another post) go below 60
