VrayLightMtl Options
Status: declined
Could we have more options in VrayLightMtl
I know that there is Vray Mesh Ligth but sometimes its not very practical to convert objects to Light specially when its a part from an object, we need to detach elements and then convert them to Lights.
Submitted on AHA Ideas (VRAYMAX-I-79).
Hi, could you clarify exactly what you’d like included in the settings for VRayLightMtl? This will help us understand the task more clearly. Thank you!
Submitted on AHA Ideas.
Hi
Sorry for not include a complete idea, I was thinking that we could have some of the options from the Vraylight, such as, affect diffuse/specular/atmosphere, Directionality, like I said before, these options are in MeshLight but there are sometimes that its more useful to apply the material from objects that has multielements.
Sorry I think I post this only visible for me and chaos employees, how do I change it?
Hi. Thank you for the details.
The idea is still not published. After we clarify and iron out the requirements we could publish it.
Directionality is available only for Disc and Plane light. It requires a flat surface from which to emit the light. By using a mesh we cannot guarantee this surface.
For diffuse, spec, and atmosphere, this might be possible when Direct illumination is checked but I will have to check it further with the devs before I can confirm.
Thank you again.
This feature could contradict with other settings and Render elements.
AHA Ideas status: Declined.
Set during AHA Ideas to Discourse migration.
