VRayLightMtl vs Vray Lights
I’m a Corona user, but was testing Vray to see about the speed possibly for animations. I created a scene that matches a Corona scene but noticed that it took so much longer to render and it was much noisier. I found the culprit to be VRayLightMtl. VRayLightMtl seems to kill the scene vs actual Vray lights. In Corona, Corona Light Material works exactly like Corona lights. Same speed and noise. Why is Vray having such issues with VRayLightMtl?
Mind if you send the test scenes so we can take a look?
From my experience you don’t need a scene, it happens in every interior scene I tried that uses Vraylightmtl for lights instead of Vray lights. If you really need one I’ll convert one of my Corona ones that I tried.
Please, do.
Okay I’ll put Together a scene.
One is a plane with a lightMtl, the other an arealight, both rendered to convergence.
make sure your vrayLightMtls have direct illumination active:
image.png​
Thank you Lele, I’m gone from the office for a week, so I didn’t get a chance to put together the scene. But I’ll put it together. I’ve tried three different scenes and all of them render way slower with V-Ray light material than using actual V-Ray lights, and much noisier also. I’ll get a scene as an example to show.
That would be the case indeed if the lightMtl was left to only emit GI (i.e. with that option turned off).
Did you convert from Corona? That would then produce consistent results across scenes (i.e. all converted the same way.).
EDIT: i checked the converter code, and so long as the corona material was a light material, we enable direct lighting if it was enabled in the Corona one.
However, that won’t work for corona materials with self illumination.
We’ll have to wait for the scene to be sure.
Hi Lele,
I’m not sure what happened, I could of sworn I replied to your last message with a basic scene a long time ago. But I just came here because of finding an issue again with the latest V-Ray and noticed there was no message from me.
I had to stay with Corona after having the light issues and a few other issues I was having with V-ray. I tested out the new version to see if there where changes to things that I had issues with and I found I’m still having this LightMtl issue. But I found what the issue is, I have it all set right to “Direct illumination” on. The issue is that the Vray LightMtl when it is under a “Multi/Sub Object Material” doesn’t work. If I break the object or light apart and use the same LightMtl on the light part it works fine. But that means I would have to go through and break apart all objects and lights that have a VRay LightMtl on it and that is just not worth the time. Can you test this and confirm?
This is expected, yes.
Assume it’s analogous to creating an object light: it can only be made with the full set of triangles in the mesh being emitters.
Sampling direct lighting from sub-materials/sub-meshes for us would be very slow, currently.
