Hi. The “emit light on back side” feature of VRayLightMtl doesn’t work in V-Ray 6 Update 1.2. I tested both RTX and CUDA. The help docs say it should be supported. Is this a bug or are the help docs wrong? I’ve plugged the VRayLightMtl into a Double Sided material as a workaround.
“Emit light on back side” indeed is not supported with GPU yet, we have it logged for improvement (internal tracking number:VGPU-718 ).Thank you for the report and apologies for the inconvenience! We will check the doc pages and bring them up-to-date in that regard.
Best Regards
Thanks for clarifying, Maria.
Hi Vray team,
Is this still unsupported on GPU? It really seems like an elementary feature for those of us who can’t afford to render on a CPU need to use.
Thanks,
Hey, @trainofthought . You should be able to work around this problem by putting the VrayLightMtl into the “Front material” slot of a Vray2sidedMtl and setting the Translucency color to black. Then apply this 2sided material to the object. I think this is how I made it work with GPU when I found this problem.
Thanks Alex, I will try this! :idea:
