VRayLightRect - Texture - Show in viewport
Hi all
when we switch on the ‘Show in viewport’ in some Maya scenes we then can’t turn it off, or we can turn it off, but it doesn’t turn off.
Same goes for switching off ‘Show in viewport’, and then we can’t turn back on.
Only solution is to reload the scene file.
The fix didn’t make it for Update 2, but it is present in the stable builds. It will most likely get in the next update.
Coolio, thanks for the info :slight_smile:
Just tested this again, and actually it did make it in Update 2. I must have made a mistake the first time I tested it. Could you try it?
yep, seems to be working, cheers.
