VRaylightselect not working with VRaySun
I have just been trying to use the VRaylightselect element with the VRaysun and it doesn’t seem to be working.
Max2012 x64 and VRay 2.4.04
Attached is a file showing the problem
Hopefully it is something simple I have missed :slight_smile:
light_select.zip (23.8 KB)
Render Elements requires VrayMaterials - in the scene you sent us not only LightSelect Element doesn’t work but all of them.
That’s because the material of the objects is Standard - if you change it to VrayMtl everything should work correctly.
