vraylightselect render element
I did put a thread in the problem section but Ive had no replies.
How do I have the light inside a room with glass work with this render element ? It just renders the glass black and I cannot see any light from within the room.
Have you enabled ‘Affect All Channels’ within the refraction options of the glass shader. Maybe try that.
Hrllo !
Had same issue, andDruski Solution worked just fine. Thanks !
