vraymat material multiple material import
I’ve just exported a bunch of materials from Maya as a single vraymat file. I can load the material library inside max using vrayVRmat material but how do I use these as separate materials within max ?
You have to duplicate the VRmatMtl several times, select the corresponding Material name from the list and then apply that material to the desired object:
okay. Thanks. I was thinking that was the case but hadn’t had time to try that yet. Cheers
