I’m having some hard time using the Translucency of the VrayMateiral in Houdini, i changed the value of translucency depth to 500 and doesn’t work properly.It looks like tranlucency is not working!
Here you can see a image with the translucency in a value of 500 and bellow you can see a image with a sss value of 5 and they both look the same. Do you have an idea of why this is happening?
Hello @gustavo_ribeiro , That’s really odd.. when I attempted to replicate your setup, it worked completely fine on my end. One thing I did notice in your screenshot is that, in the example with the alSurface material, the node is not connected to the output.
Hey i figured out, this was happening always when the values for sss Color where pure red on the vray material, if i change the red channel to 0.98 it already works fine, but if its 1 it doesn’t work!
