Vraymtl displacement scale
Im using the vraymaterial displacement and the docs say the scale is per scene unit. My scene is set to CM
This isnt correct at the moment is it? When i use a displacement modifier with the amount set to 1cm it renders as expected, with the material amount set to 1cm its more like 10cm in the render.
im using vray 7 update 4 hotfix 1
Looks correct on my end. When I switch from cm to m, the VRayMtl’s displacement texmap value correctly gets converted from 1cm to 0.01m. Compared it to a 1x1x1 poly cube, which also gets converted to 0,01 x 0,01 x 0,01 and it matches.
Something else is going on. Mind if you share a simple scene?
hi thanks for reply, s
displacement_issue.zip (236.4 KB)
cene attached
“Relative to bbox” is active in the Default displacement settings (Render Setup > Settings > Default displacement) - disable it if you want a precise displacement amount.
nice one thanks for that.
