VrayMtlConverter25 and MAXScript
I hope this is an appropriate post for this forum but-
I’ve downloaded VrayMtlConverter25 and saved it to my C:\Program Files\Autodesk\3dsmax2015\scripts folder
When I try to run the script in MAXScript, it says can’t find include file vmc_logos.mse
This file is in the same folder.
Can someone tell me how to direct MAXScript to find this missing file.
Thank You
Try to use the Installer instead of copying the files manually.
I tried that Tashko, but after installing it’s supposed to show up in Customize<Customize UI but it doesn’t.
The script doesn’t support 3DSMax 2015 - that why it is not shown it Customize UI menu.
Copy the files from the script in the following folder:
Then drag the VRayMtlConverter_v25.mse into 3DSMax and the converter should pop up:
That’s exactly what I did Svetlozar. And as I said before, I get this error-
The script doesn’t support 3DSMax Design version.
This is what I’ve got with 3DSMax 2015 Design:
It would be better to contact the author of the script directly.
