_vrayMtlFromRhino : doesn't work with Rhino PBR materials
basically, the Metallic / Roughness doesn’t get translated.
Thank you for your post!
This issue has been logged in our internal system(ref. Num. 2938 ) and will most likely be fixed in the next update.
Hi @slavcho.brusev I tried to use the alpha parameter of the PBR material and it doesn’t work. Could this be fixed too please? The direct usage of PBR materials is important for rendering Bongo animations, since the PBR parameters can be animated, but not V-Ray material parameters. Or could it be possible to get animated V-Ray material parameters too?
Hi Micha,
Our developers will research the support for this option.
Hi guys,
Full support for the new PBR material in Rhino is coming soon.
This task is logged as VRW-2938 in our system and is already in progress.
Konstantin
