I trying to test render the vray material wrapper for Maya in order to achieve ground shadows on the ground plane and making the hdr dome light image show through but after a lot of try unable to perfectly achieve this i have put the alpha contribution to -1 and all the things which have been discussed in this forum I defiantly believe i need to tweak something in the base material or something it will be great if some one can help me out or just write down there steps which works for them or point me to some tutorial so i can go through it
Do you have both GI and dome light enabled? If yes, try setting the V-Ray GI environment override to black and see if it helps.
i try this out thanks vlado
nope did not work wish i can just send you my scene file for you to have a look its a simple set up this is so frustrating as been using vray for awhile and something so simple does not work for me i can mail you the file if you can have a look
Yes, if you can send the file to vraymaya@chaosgroup.com our support guys will help you out.
thanks will do
hi valdo the emails are not working i tried the other support mail dont work were can i send the file
Why would an email not work? If the scene is too big to send as an attachment, just email our support guys and they will get you ftp info where you can upload it. Or you can use dropbox or yousendit.
my bad valdo dint read that the msg file was to big have send them a link to were the file can be downloaded thanks and sorry for the trouble
