VrayMultiSub Tex in the PHXSource Texmap Masks
i’ve big cached geometry from TP, I’d like to use the faces mat IDs to emit from (and colorize too).
Is it possible ?
Thanks !
In the PHXSource you can set the Polygon ID you would like to use.
thank you, but I’d like to use several ids, not only one.
Multiple ids per one Source are not supported - but I will add it in the to do list. For now you can make several Sources and assign different ID for each one.
Ok,
last time I tried I remember that I can’t pick one object with different PHXSources.
I’ll make a try tomorow,
Thanks !
Yup, this wont work indeed - for now just texture mapping, vertex color and a single poly ID will do.
