Sometimes I need to apply around 20+/- maps inside a single VRayMultiSubTex.
And sometime I need to apply around 20+/- maps inside many different VRayMultiSubTex.
It happens to be very confusing and time consuming, as I wish I could
Is there a way to quick assign all these maps in the slate material editor?
(i am new to the slate material editor, I used the compact for years)
The only reason I started using max more is because of the plugins and scripts actually, I think I use 50% of the basic max functions, the rest are plugins and scripts. But I can understand that it would be a nice thing to have.
I have a lot of objects with sometimes huge multisub materials with a lot of maps. There are a lot of cases I am not satisfied with the whole object gamma, color or brightness and I want to change it.
I found a way to do this but it requires a lot of time connecting to the VRayMultiSubTex, so I am searching for a quick solution.
I have tried slate connector. It seems to work fine with corona (according to user feedback) but I couldn’t make it work with 3ds max 2016.
I understand, but is loading something else than bitmaps really needed? I haven’t seen any request of someone wanting to load 20 different noise maps.
I think the most important is having a multi map loader with possibility to change hue/sat/gamma value. Essentially, it should replace multi-texture for those who don’t want to work with outside plugs, or like me, who like to get that working in RT
I just set up VrayMultiSubTex to object ID, connected all desired maps to it, output to color correction and then the color correction output back to all vraymtls in the multisub.
It worked just fine, but it takes very long time to connect all the dots.
