Hi, i’ve a problem with a material…
It’s a wood material with diffuse, reflect and bump maps. For by pass the not supported multitexture plugin i’ve used VrayMultiSubTex in any maps.
The problem is between vrayrt and vray standard.
If i Activate or deactivate bump map (VrayMultiSubTex with 15 normal bump) the result is respectively different or the same in the two renderer.
I’m attaching some images for explain my problem…
Vray__BUMP VrayMultiSubTex ON
Vrayrt__BUMP VrayMultiSubTex ON/OFF
Vray__BUMP VrayMultiSubTex OFF
I think VrayMultiSubTex is supported because it works fine in diffuse and reflect maps..
Any advice?
No need for the scene, I can see the problem. Have you tried doing it the other way round, i.e. using just one Normal Bump map, and connecting the VRayMultiSub texture to that?
