bardo
1
I’ve found a problem with VrayClipper.
As you can see, some white quads appear.
In the side view you can see the VrayClipper.
I’ve tried to replicate in a clean project with no luck.
If you want a prepare an archive, let me know which email address should I sent it.
Thanks in advance
matanov
2
Can you check for overlapping faces?
bardo
3
it’s a bit strange that problem cause if I stay outside the window glass I have the problem, if leave the window glass behind the camera all is fine.
Overlapping between the vrayclipper object and the objects “clipped” by it?
