VRayNext & HairFarm
Material diffuse texmap is not rendered on Hair Farm hair. Is there any way to fix it?
Seems to work correctly in a quick test here, are you on the latest Hairfarm beta build? Also what is the exact V-Ray next version ?
Can you give me your max file just in case ?
Thanks!
Hairfarm 2.6.3
VrayNext 4.10.03
3ds Max 2016
You can see attached file.
prueba.rar (31.4 KB)
Seems there is some issue that we’ll have to look into, but the result is that the mapping coordinates are on channel 2. When we tried to create the scene here they were on channel 1 so we’ll be looking into why there is such mismatch. As a temporary workaround the texmap can be set to UVW channel 2.
Alexander
Hi, this should be fixed with the next update.
Alexander
