vraynormalmap error
Not sure what the problem is. I can’t seem to set the max parameter for the vraynormalsmaps higher than 30 otherwise I get this error.
Any reason for this ?
What is the geometry (regular mesh or proxy)?
Just a regular mesh with turbosmooth
Would be best if you can get me a scene then; somewhat hard to say what’s going on.
Will do. Whats your email ?
Did you get the file I sent Vlado. I really need to get this render sorted for a client…Thanks
Have a real close look at your normal map…depending how it was produced, you MAY see it is not smooth but looks like it’s layered with edges.
Put it back into photoshop & do a slight Blur & see if that helps
I used crazybump to create it… I’ll take a look at it in photoshop though to see if there are any “features”
This is the normal map im using.. looks fine to me.
Any progression with this Vlado…my client is getting quite desperate !
You have set the gamma for the normal map to 2.2 - this is not necessary. Set it to 1.0 and it will be fine.
Doh, silly me. Thanks for letting me know.
Maybe it already does by now, but it would be cool if the gamma for a VrayNormalMap was automagically set to 1.0 to avoid this sort of thing. It’s not like you would *ever* want a 2.2 normal map…
