VRayOCIO texture in this setup has no effect:
In CPU mode everything is OK.
BTW
VRayOCIO texture doesnt work with VRayMultiSubTex. This setup doesn’t work:
Huh, it works for the preview only. Odd. I’ll investigate further, however, you can set the RGB Primaries of the VRayColor directly to ACES, so there isn’t really a necessity for conversion.
Right. Just so you know, I’ve logged the issue (internal bug-tracker id: VGPU-5557) for developer investigation.
Thank you Aleksander ![]()
