I recently installed the much anticipated 3.1.x verion and it’s awesome.
But I might have found a little bug with the tilt-funtion in comination with hidden object for VrayPhysCam.
When I hide cameras in a scene (wether its done by ‘hide object’ or by the ‘Hide by Category’-Tab) the automatic tilt-effect will be disabled in the viewport.
This was working before. Using Max 2014 here.
Could you replicate the error?
I don’t think this was working before (at least, it has been reported since a while). We looked into it, but doesn’t look like it’s something that we can fix on our end.
Thanks for the heads up.
Well it worked ever on my PC, but no more after the SP1 update.
It doesn’t matter that much, however. If the actual/active Cam is the only one in the scene, that’s perfectly fine how it is now.
