vrayphysicalcamera depth of field subdivs
Can I set the subdivs to a value higher than 100 somehow? maxscript?
Yep, $.subdivs = 200 will do it for the selected camera. It won’t reflect the change in the ui, but if you just use $.subdivs in the listener it should return 200.
groovy, thanks John. Add another beer to the queue of beers I owe you.
All good geezer - must get over to 3dslondon some stage soon!
You can also just up the DMC image sampler subdivs… the result will be exactly the same.
