not sure if this has been asked already, can the vignetting be turned off as default in the upcoming SP2?
maybe i’m the only one who turns it off all the time? it lacks the control Lightroom/Camera RAW has so i do my vignetting there if at all on visualisation work.
then again, maybe it can be incorporated as a separate render element…
I’ve found myself turning it off more and more as I work on more projects. If I need vignetting, I could always add it in post with greater control afterwards.
I don’t agree… the vignette is actually a very useful thing in simulating a realistic camera.
If you don’t like it, why not using 3dsmax standard camera?
It’s a feature of a physical camera, if it wasnt on by default then too many people wouldnt know about it or use it. And it’s only one checkbox you need to click, which is right next to all your exposure settings that you’ll be clicking on anyway.
I’d say it’d hinder more people than it’d help by making it off by default.
true, it is an effect of some physical camera lenses, but more often than not it’s unintended and undesired. only sometimes is it purposely introduced for creative effect.
its actualy an effect on all lenses, but is usualy more pronouched at wide angle, large/wide apertures…which kinda means that the effect that the vray camera produces is not phisical anyway, as the apertures settings seem to have no effect on it.
Also, if ever I need the effect Ill just add it in PS
so in that respect I also think it should also be turned off by default..if only to save me one click
Most professional photographers will actually remove vignetting found in their photos. One of the main reasons this has been introduced is to lend 3d images a bit more realism but in turn essentially amounts to a bad (or perhaps accurate) photograph.
Personally, I find the default values to be a bit on the strong side and often go back and forth in post.
As for using the physical camera - there’s far more advantages that go well beyond the standard max camera. I’m not go into detail as to why I would use it over a max camera.
Either way, it’s not a big deal to check a box. Two things I would like turned off by default are Vraylights set to invisible on creation and vignetting turned off by default.
using maxstart.max, I create a camera and set it up to the default I love.
Then everytime max startup, the camera is already set. Don’t even have
to tweak it.
