vrayplane60.dlo not found using backburner
even though its in the vray-plugins directory and the path is set in the plugin.ini, vrayplane60.dlo is not found at rendertime using backburner.
any ideas??
andré
I think that’s a Max bug, try to put the two directories from Vray in last, if that doesnt work, try put them in first. Good luck.
