VRayProxy Mangles Imported Houdini Alembic Channels Unless Subdivision is Enabled
I imported an Alembic created in Houdini using VRayProxy. I can see from the Vertex Color node connected to the assigned material that the channels are present. But when I render the object with the channels the data is incorrect.
If I enable Subdivison (Subdivide All Meshes) in the VRayProxy settings then everything works as it should. If I set the subdivison level to 0 the results are again incorrect. The subdiv level must be at least 1.
If I load the ABC into the Max ABC importer it also works correctly.
Can anyone else confirm this? Thanks.
Joe, could you mail me the files? (Any you can share under NDA)
OK. Sent you an email.
I think I found a workaround:
I think I may have just found a workaround. It looks like if I reorder the map for the channels I want into Map slot1 (and update the vertex map settings accordingly) then it works correctly.
Just in case it matters. Running the nightly from 2023-12-29. Build 32397
