Is this supported? My tests are based on the below instructions for Vray and I can’t get it to work
https://forums.chaos.com/forum/v-ray-for-3ds-max-forums/v-ray-for-3ds-max-problems/1000361-vrayproxy-doesn-t-render-displacement-in-material
Hi rita_sobral,
I my test the displacement works fine on proxy objects(I tried it on a cosmos tree asset): https://drive.google.com/uc?id=1V6hgqJPO9pIKNpL1awQfVMDdnSW8\_HWH
Can you please hare the scene you are testing with so we can investigate?
Alexander
I had ‘Emulate 2d Displament’ turned on in Vantage and that looks to be the issue. However, vray displacement worked normally otherwise, on non proxy objects and with 3d mapping set… So perhaps that setting is causing an issue only with proxies?
THanks
