VRayProxy reloads non-animated vrmesh files on frame change
I am using V-Ray v7.40.02 and experiencing an issue with non-animated vrmesh files loaded via the VRayProxy node.
In our project, we have converted a massive number of buildings into individual vrmesh proxies (one unique file per building). Even though these are completely static (non-animated) files, V-Ray seems to reload or re-evaluate them every time I move the time slider.
I tried changing the “Playback type” to “Still”, but the issue persists.
With the older (classic) “VRayMesh” node, we were able to work around this behavior by disconnecting the time node, but this workaround has no effect with the VRayProxy node.
Additionally, when “Geometry to load” is set to “Full geometry”, the viewport slowdown becomes extremely severe. Because we have so many unique proxies, it behaves as if it is repeatedly reading all of those heavy files from the disk, making it almost impossible to capture a Playblast smoothly.
Could you please look into this and improve the caching or file-evaluation behavior for static proxies in the VRayProxy node?
We are aware of the issue, and it’s already logged for dev investigation (VMAYA-12017).
Just to confirm - does the viewport performance improve if you set the VRayProxy’s Preview to None?
Thank you for confirming that it’s already logged.
To answer your question:
If the Preview is set to “None”, the viewport performance is fast enough that we can play back the timeline.
However, if it is set to “Bounding box”, although it is slightly better (faster) than “Full geometry”, it is still far too heavy and we cannot play back the timeline smoothly at all.
I hope this distinction helps the dev team with their investigation!
Thanks. Will include this info in the log. I’ll also talk to the product owner to raise the priority of the issue.
