Vrayproxy scale parameter rename
Would it be possible to rename the maxscript reference to the vrayproxy’s native scale parameter?
At them moment it’s using the same name as the node’s transform scale parameter so you can’t access it. Unless I’m being a bit slow…
Thanks,
Olly
Thanks for the pointer; this is now changed for SP3 (to “proxy_scale”).
