Vrayraw60.bmi error through backburner
Hi there,
keep getting above Task error when rendering through backburner - onto slave renderers. It works fine if I render through backburner onto my manager PC though.
Standard Install as with all other versions - now on max 2008…
Any ideas?
Thanks,
How odd; vrayraw60.bmi is the image loader for .vrimg files for 3ds Max 6/7/8; maybe this file was left behind by mistake? Do you actually have the file in the plugins folder of 3ds Max 2008?
Yeah the file vrayraw60.bmi is in there. I uninstalled then reinstalled while watching the plugin folder…, it’s the install that’s creating it? It’s not there on my Manager though?
Strange, on one other PC it has both vrayraw90 and vrayraw60 files. Another has just the 60 files…, all from same Install file.
It is odd, but in any case removing the vrayraw60.bmi file should solve the problem.
Hi Vlado,
that worked on one slave. However, every other slave only has vrayraw60.bmi and vrender60.dlr in the plugin root (unlike my manager and the one other I’ve got working - they both have the *90* files. Everytime I try to reinstall the *60* files are the only two files the install creates.
Any ideas? (I’ll try to download the install from Chaos website again)
update
Hi Vlado,
found the problem - as always - LACK OF SLEEP! Gettign my Install for v8 and 2008 mixed up.
Apologies
Ah, ok. Glad that it’s solved then.
