Is this an RT problem?
I got a VRayPhysicalCamera with normal parameters (exposure ticked) but chaning shutter value or anything relating to exposure has ZERO effect on the image.
WHen I use the production renderer it works as expected.
Is this a know issue?
I also made a new camera and copy pasted paramaeters, still zero effect.
It seems that if RT is started while sup-pixel mapping is turned on, then no luck with exposure, but if RT is started with SPM turned OFF, then you can change exposure, turn SPM back on and still change exposure… odd.
