Did you run the installer by double-clicking it, or by right-clicking and then Run as administrator…?
I have had the same problem (VRay RTEngine.DLL not found ) but not on max 2010, it was on 2009. Apparently, 2010 worked fine!. Same OS, Vista 64bit SP1
double-click
But I am an administrator.
I did the install using both methods, nothing worked
Vista will not grant the installer access to the program files folder unless you specifically choose the “Run as administrator…” option (or turn UAC off), even if your user has administrative privileges.
Ok then, there are several things to check:
1) make sure the RT engine really is where it should be - “C:\Program Files\Chaos Group\V-Ray\RT for 3ds Max 2010 for x64\bin\plugins”, the file is called “vray_RTEngine.dll”
2) make sure that the environment variable VRAY_RT_FOR_3DSMAX2010_PLUGINS_x64 is defined properly. To do that, right-click “My Computer”, choose “Properties”, select “Advanced system settings”, click on the “Environment variables” button, scroll down the “System variables” list and see if there is an environment variable named “VRAY_RT_FOR_3DSMAX2010_PLUGINS_x64” and that its value is the path from point 1)
Are these two things ok on your system?
Yes, it is there, main_x64 to bin and plugins_x64 to bin/plugins
Ok, then; not quite sure why it would happen, but try the following:
1) Open a command prompt (Start menu > enter “cmd” without the quotes in the “Start search” box and press Enter;
2) In the command prompt, type “set” without the quotes and press Enter; make sure that you see the “VRAY_RT_FOR_3DSMAX2010_PLUGINS_x64” variable.
3) Start 3ds Max directly from the command prompt: type “c:\program files\autodesk\3ds Max 2010\3dsmax.exe” with the quotes and press Enter;
4) See if that works.
it works!!!
Hm ok then. If you reboot Windows, does it work with the normal 3ds Max shortcut?
Ok, it works. There was a problem because of shortcut in sidebar of vista. When I put shortcut on desktop, everything is ok, thanks a lot.
But why it didnt work with shortcut in sidebar ? (appliaction - App Launcher V3)
It is because the App Launcher did not immediately update the contents of the environment variables, which V-Ray RT for 3ds Max needs to find the V-Ray Standalone plugins.
Less limited demo
A Less limited demo would be great, really just need more objects.
Main thing for people who do not have render farms would be to see if single machine can run Vray RT smoothly, before spending the money and finding their machine comes to a grinding halt when trying to run it.
Look forward to any updates, hopefully before the special introductory price expires
Cheers
Derek
I totally agree.
When you consider that we can download and install a fully functional copy of max limited to 30 days, and worth 5 times the price or more, the RT demo seems restricted with a level of paranoia that I’ve never seen before!
Why not make it fully functional but expire at the end of June or even 1 weeks time?
From what I have seen of it though, I’m a bit disappointed that the activeshade window doesn’t update a bit more interactively, rather than going back to black and re-rendering the whole view This makes it difficult to make fine adjustments or am I missing something here?
Cheers,
Olly
I agree, it’s annoying.
I guess making a more functional demo makes it easier for crackers to remove the restrictions and release it as a cracked “full version”.
If something is changed, the calculation does start from the beginning, but quite fast so. the window never really gets black. overall it feels quite smooth, especially if only the view is changed.
With radiosity (the good old lightscape), if a color was changed, the calculation didn’t start again, but adapted to the new value.
this would be cool, but also wrong in many situations, like it would be impossible for reflections to adapt (i guess).
What i’m more concerned about, is that many little settings in maps, etc. are not supported, or look differently than the final render with vray, which shouldn’t happen with a realtime preview/tweaking tool.
But i’m sure this will improve in the next months.
Vray standalone is impressive, i’m looking forward for standalone to replace vray 1.5 for final rendering too. (linux render nodes finally?). ![]()
It doesn’t when I have a teapot on a vrayplane lit by a vray sun and sky, but I’m afraid it does on this production scene I’m working on: http://www.chaosgroup.com/forums/vbulletin/showpost.php?p=402695&postcount=6
Cheers,
Olly
It would be extremely helpful if you let us know for any such omissions so that we can correct eventually.
Hm, we have tested it on quite more complicated scenes, and was not too bad; it may be useful if we could take a look at that scene, but I would understand if it’s not possible.
Vlado I’ve PM’d you…
Cheers,
Olly
Let me briefly clarify my position,
…most of us are long time VRay users and during these years we have received a lot of extra features without paying nothing more than the initial price, great forum support directly from dev team, on so on…
Said that…
I’m sorry Chaos; but totally agree with that statement!
For me the 15 objects limit it’s not a great issue; my suggestion is to leave as demo limitation the resolution, the number of object and the number of seconds for every active shade session, that is enough!
…just please remove the 5 active shade window for 3ds max session limit!!!
Another option could be release a free limited version and a pro/adv or whatever; I suppose that for most of us that was exactly the entrance into the VRay world some years ago.
That is my disappointment as well; for instance, I believed that I could have used RT to clarify myself how sub scattering really works but after some time spent on tweaking values I discoverded that, 'till now, it’s not supported ![]()
So, IMHO, actually it’s really very difficult to evaluate a purchasing option!
